# LIFX Binding
| Device Type | Thing Type |
| Original 1000 | colorlight |
| Color 650 | colorlight |
| Color 1000 | colorlight |
| Color 1000 BR30 | colorlight |
| LIFX A19 | colorlight |
| LIFX A21 1600lm | colorlight |
| LIFX BR30 | colorlight |
| LIFX Candle | colorlight |
| LIFX Ceiling | colorlight |
| LIFX Downlight | colorlight |
| LIFX GU10 | colorlight |
| LIFX Mini Color | colorlight |
| LIFX PAR38 | colorlight |
| LIFX Round Spot | colorlight |
| LIFX Round Path | colorlight |
| LIFX Square Path | colorlight |
| LIFX Clean | colorhevlight |
| LIFX+ A19 | colorirlight |
| LIFX+ BR30 | colorirlight |
| LIFX Beam | colormzlight |
| LIFX Neon | colormzlight |
| LIFX Outdoor Neon | colormzlight |
| LIFX String | colormzlight |
| LIFX Z | colormzlight |
| LIFX Tile | tilelight |
| White 800 (Low Voltage) | whitelight |
| White 800 (High Voltage) | whitelight |
| White 900 BR30 (Low Voltage) | whitelight |
| LIFX Candle Warm to White | whitelight |
| LIFX Filament | whitelight |
| LIFX Mini Day and Dusk | whitelight |
| LIFX Mini White | whitelight |
| Thing Type | On/Off | Brightness | Color | Color Zone | (Abs) Color Temperature | (Abs) Color Temperature Zone | HEV Cycle | Infrared | Tile Effects |
| colorlight | X | X | X | ||||||
| colorhevlight | X | X | X | X | |||||
| colorirlight | X | X | X | X | |||||
| colormzlight | X | X | X | X | X | ||||
| tilelight | X | X | X | X | X | ||||
| whitelight | X | X | X |
| Channel Type ID | Item Type | Description | Thing Types |
| abstemperature | Number:Temperature | This channel supports adjusting the color temperature in Kelvin. | colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight |
| abstemperaturezone | Number:Temperature | This channel supports adjusting the zone color temperature in Kelvin. | colormzlight |
| brightness | Dimmer | This channel supports adjusting the brightness value. | whitelight |
| color | Color | This channel supports full color control with hue, saturation and brightness values. | colorlight, colorhevlight, colorirlight, colormzlight, tilelight |
| colorzone | Color | This channel supports full zone color control with hue, saturation and brightness values. | colormzlight |
| effect | String | This channel represents a type of light effect (e.g. for tile light: off, morph, flame) | tilelight |
| hevcycle | Switch | This channel supports starting and stopping the HEV clean cycle. | colorhevlight |
| infrared | Dimmer | This channel supports adjusting the infrared value. Note: IR capable lights only activate their infrared LEDs when the brightness drops below a certain level. | colorirlight |
| signalstrength | Number | This channel represents signal strength with values 0, 1, 2, 3 or 4; 0 being worst strength and 4 being best strength. | colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight |
| temperature | Dimmer | This channel supports adjusting the color temperature from cold (0%) to warm (100%). | colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight |
| temperaturezone | Dimmer | This channel supports adjusting the zone color temperature from cold (0%) to warm (100%). | colormzlight |
The color and brightness channels have a "Power On Brightness" configuration option that is used to determine the brightness when a light is switched on. When it is left empty, the brightness of a light remains unchanged when a light is switched on or off.
The color channels have a "Power On Color" configuration option that is used to determine the hue, saturation, brightness levels when a light is switched on. When it is left empty, the color of a light remains unchanged when a light is switched on or off. Configuration options contains 3 comma separated values, where first value is hue (0-360), second saturation (0-100) and third brightness (0-100). If both "Power on brightness" and "Power On Color" configuration options are defined, "Power on brightness" option overrides the brightness level defined on the "Power on color" configuration option.
The temperature channels have a "Power On Temperature" configuration option that is used to determine the color temperature when a light is switched on. When it is left empty, the color temperature of a light remains unchanged when a light is switched on or off.
MultiZone lights (colormzlight) have several channels (e.g. colorzone0, temperaturezone0, abstemperaturezone0, etc.) that allow for controlling specific zones of the light. Changing the color, temperature and abstemperature channels will update the states of all zones. The color, temperature and abstemperature channels of MultiZone lights always return the same state as colorzone0, temperaturezone0, abstemperaturezone0.
The hevcycle channels have an optional "HEV Cycle Duration" configuration option that can be used to override the cycle duration configured in the light.
LIFX Tile (tilelight) supports special tile effects: morph and flame. These effects are predefined to their appearance using LIFX application. Each effect has a separate speed configuration option.
The desk light is a LIFX Clean that has a colorhevlight thing type which supports color, temperature and hevcycle channels.
# demo.things Example
Thing lifx:colorhevlight:desk [ deviceId="D073D5A3A3A3" ] {
Type hevcycle : hevcycle [ hevCycleDuration=3600 ]
# demo.items Example
// Living
Number:Temperature Living_Abs_Temperature "Living Room Lights Color Temperature [%d K]" { channel="lifx:colorlight:living:abstemperature" }
Number:Temperature Living2_Abs_Temperature "Living Room Lights Color Temperature [%d K]" { channel="lifx:colorlight:living2:abstemperature" }
// Desk
Color Desk_Color { channel="lifx:colorhevlight:desk:color" }
Dimmer Desk_Temperature { channel="lifx:colorhevlight:desk:temperature" }
Number:Temperature Desk_Abs_Temperature "Desk Lamp Color Temperature [%d K]" { channel="lifx:colorhevlight:desk:abstemperature" }
Switch Desk_HEV_Cycle { channel="lifx:colorhevlight:desk:hevcycle" }
// Porch
Number:Temperature Porch_Abs_Temperature "Porch Light Color Temperature [%d K]" { channel="lifx:colorirlight:porch:abstemperature" }
// Ceiling
Number:Temperature Ceiling_Abs_Temperature "Ceiling Light Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperature" }
Number:Temperature Ceiling_Abs_Temperature_Zone_0 "Ceiling Light 0 Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperaturezone0" }
Number:Temperature Ceiling_Abs_Temperature_Zone_15 "Ceiling Light 15 Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperaturezone15" }
// Kitchen
Number:Temperature Kitchen_Abs_Temperature "Kitchen Light Color Temperature [%d K]" { channel="lifx:whitelight:kitchen:abstemperature" }
# demo.sitemap Example
Frame label="Living" {
Switch item=Living_Color
Slider item=Living_Color
Colorpicker item=Living_Color
Slider item=Living_Abs_Temperature
Frame label="Living2" {
Switch item=Living2_Toggle
Slider item=Living2_Dimmer
Slider item=Living2_Abs_Temperature
Frame label="Desk" {
Switch item=Desk_Color
Slider item=Desk_Color
Colorpicker item=Desk_Color
Slider item=Desk_Temperature
Slider item=Desk_Abs_Temperature
Switch item=Desk_HEV_Cycle
Frame label="Porch" {
Switch item=Porch_Color
Slider item=Porch_Color
Colorpicker item=Porch_Color
Slider item=Porch_Temperature
Slider item=Porch_Abs_Temperature
Slider item=Porch_Infrared
Frame label="Ceiling" {
Switch item=Ceiling_Color
Slider item=Ceiling_Color
Slider item=Ceiling_Abs_Temperature
Slider item=Ceiling_Abs_Temperature_Zone_0
Slider item=Ceiling_Abs_Temperature_Zone_15
Frame label="Kitchen" {
Switch item=Kitchen_Toggle
Slider item=Kitchen_Abs_Temperature
