# Tellstick Binding
dimmer - Switchable Device - On/Off only could be lamps or other electronic equipment.
switch - Sensors - Temperature- and humidity-sensors.
sensor
telldus-core - Telldus Live Bridge - Telldus Cloud service, all devices with online access.
telldus-live - Telldus Local Bridge - Telldus Local API, Tellstick Net v2/Tellstick ZNet Lite v1/v2.
telldus-local
# Switchbased sensors workaround
switchThings instead of typecontact. There is technically no way of distinguish them apart from regulurswitchThings. For using them as sensors only (not paired to a lamp) please consult the workaround in the channel section.
# Binding Configuration
# Dimmers & switches
Use the option repeat for that. Default resend count is 2.
# Bridges
Depending on your Tellstick device type there is different ways of using this binding.
The binding implements three different APIs:
3) Telldus Local which is a REST based local service maintained by Telldus.
| Model | Telldus Core | Telldus Live | Local REST API | Verified working with openHAB |
| Tellstick Basic | X | X | X | |
| Tellstick Duo | X | X | X | |
| Tellstick Net v.1 | X | X | ||
| Tellstick Net v.2 | X | X | ||
| Tellstick ZNet Lite v.1 | X | X | X | |
| Tellstick ZNet Lite v.2 | X | X |
# Telldus Core Bridge
java -d32 -versionFor changing architecture in Linux check out:
dpkg --add-architecture
Optional:
# Telldus Live Bridge
To configure Telldus Live you have request OAuth tokens from Telldus. Goto this page https://pa-api.telldus.com/keys/index (opens new window) and request your keys and update the config.
Required:
- privateKey: Private key
- publicKey: Public key
- token: Token
- tokenSecret: Token secret
Optional:
# Telldus Local Bridge
Required:
- ipAddress: Local IP address of your Tellstick device
- accessToken: Access Token
Optional:
- refreshInterval: How often we should contact Telldus Local to check for updates (in ms)
| dimmer | Number | This channel indicates the current dim level |
| state | Switch | This channel indicates whether a device is turned on or off. |
| timestamp | DateTime | This channel reports the last time this device state changed. |
| humidity | Number:Dimensionless | This channel reports the current humidity in percentage. |
| temperature | Number:Temperature | This channel reports the current temperature. |
| timestamp | DateTime | This channel reports the last time this sensor was updates. |
| watt | Number:Power | This channel reports the current watt. |
| ampere | Number:ElectricCurrent | This channel reports the current ampere. |
| windgust | Number:Speed | The current peak wind gust. |
| winddirection | Number:Angle | The current wind direction. |
| windaverage | Number:Speed | The current wind average. |
| rainrate | Number:Length | This current rate of rain. |
| raintotal | Number:Length | The total rain. |
All switchbased sensors are binary and the goal is to represent them as a contact item in openHAB. Eg. a door is open or closed and can't be altered by sending a radio signal.
rule "proxy_front_door_on"
rule "proxy_front_door_off"
# tellstick.things
# tellstick.items
