# Developing a Binding
# Describing Things
# The ThingHandlerFactory
@NonNullByDefault
@Override
@Override
return null;
# The ThingHandler
If the framework wants the binding to do something or just notify it about changes,
The BaseThingHandler provides convenience methods like updateState, updateStatus updateThing or triggerChannel, that can be used to inform the framework about changes.
TODO
# Lifecycle
# Startup
Handler is registered:
ThingHandlerinstance is created by aThingHandlerFactoryand tracked by the framework. In addition, the handler can be registered as a service if required, e.g. asFirmwareUpdateHandlerorConfigStatusProvider.Handler is initialized:
ThingHandler.initialize()is called by the framework in order to initialize the handler. This method is only called if all 'required' configuration parameters of the Thing are present. The handler is ready to work (methods likehandleCommand,handleUpdateorthingUpdatedcan be called).The diagram below illustrates the startup of a handler in more detail. The life cycle is controlled by the
ThingManager.
# Shutdown
Handler is unregistered:
ThingHandlerinstance is no longer tracked by the framework. TheThingHandlerFactorycan unregister handler services (e.g.FirmwareUpdateHandlerorConfigStatusProvider) if registered, or release resources.Handler is disposed:
ThingHandler.disposed()method is called. The framework expectsdispose()to be non-blocking and to return quickly. For longer running disposals, the implementation has to take care of scheduling a separate job.
# Bridge Status Changes
The following types are supported for configuration values: Boolean, boolean, String, BigDecimal, int, long, float and double.
# Properties
Things can have properties. If you would like to add metadata to your thing, e.g. the vendor of the thing, then you can define your own thing properties by simply adding them to the thing type definition. The properties section here explains how to specify such properties.
To retrieve the properties one can call the operation getProperties of the corresponding org.openhab.core.thing.type.ThingType instance.
Therefore the org.openhab.core.thing.Thing interface also provides the getProperties operation to retrieve the defined properties.
# Handling Commands
@Override
try {
switch (channelUID.getId()) {
case CHANNEL_TEMPERATURE:
break;
@Override
updateWeatherData();
break;
case CHANNEL_HUMIDITY:
# Updating the Channel State
# Polling for a State
@Override
public void initialize() {
private void pollingCode() {
@Override
public void dispose() {
final job = pollingJob;
if (job != null) {
job.cancel(true);
pollingJob = null;
# Trigger a channel
triggerChannel("channelId")
# Updating the Thing Status
At this time the state of the thing is INITIALIZING as long as the binding sets it to something else.
# Channel Links
# Updating the Configuration
# Updating Thing Properties
updateProperties(properties);
# Handling Thing Updates
@Override
dispose();
this.thing = thing;
initialize();
# Bridges
We have a FAQ, discussing Thing, Bridge and Channel modelling.
@Override
break;
case CHANNEL_ID_COLOR:
A BridgeHandler handles the communication between the openHAB framework and a bridge (a device that acts as a gateway to enable the communication with other devices) represented by a Bridge instance.
# The BaseBridgeHandler
# Life cycle
- A
BridgeHandlerof a bridge is initialized beforeThingHandlers of its child things are initialized. - A
BridgeHandleris disposed after allThingHandlers of its child things are disposed.
# Config Status Provider
For this purpose the handler of the entity implements the interface org.openhab.core.config.core.status.ConfigStatusProvider.
A ThingHandler as handler for the thing entity can provide the configuration status of the thing by implementing the org.openhab.core.config.core.status.ConfigStatusProvider interface.
org.openhab.core.thing.binding.ConfigStatusThingHandlerextends theBaseThingHandlerand is to be used if the configuration status is to be provided for thing entitiesorg.openhab.core.thing.binding.ConfigStatusBridgeHandlerextends theBaseBridgeHandlerand is to be used if the configuration status is to be provided for bridge entities
Sub-classes of these handlers must only override the operation getConfigStatus to provide the configuration status in form of a collection of org.openhab.core.config.core.status.ConfigStatusMessages.
After the removal was requested (i.e. the thing is in REMOVING state), it cannot be changed back anymore to ONLINE/OFFLINE/UNKNOWN by the binding.
# Actions bound to a Thing
Examples are:
- Reboot / Restart device
You start things off by implementing ThingActions and annotate your class with @ThingActionsScope.
The scope name should be the binding name.
There is a limitation that only one ThingActions class with the same scope per thing type is allowed, so if you need to provide several ThingActions classes for a single thing type, you can append a -xxx to the scope names.
Since a new service is required for each thing, the component needs to be a PROTOTYPE:
@Component(scope = ServiceScope.PROTOTYPE, service = MQTTActions.class)
@NonNullByDefault
@Override
@Override
@Override
return List.of(MQTTActions.class);
In the following example we provide a publishMQTT action.
If an action should be available as rule action and through the REST API (and this way also through the UI), it must be annotated with @RuleAction and a label and a description must be provided.
Please think about the intended use case for your action and decide based on this whether to add the @RuleAction annotation.
For example actions returning a list of future prices are very practical in automation languages, but not so much in the UI.
public void publishMQTT(
If an action method is annotated with @RuleAction, each parameter of it must be annotated with @ActionInput.
As action inputs can only be provided in serialised form by rule actions and through the REST API, only a limited set of input types are supported for those.
If an action method has input parameters that have an unsupported type, the action cannot be used as a rule action (in UI-based rules) or invoked from the REST API.
It can however still be invoked from automation languages.
The supported input types are (see ActionInputHelper (opens new window) for more details):
- all primitive types, e.g.
boolean,int,float,String, and their boxed counterparts org.openhab.core.library.types.DecimalTypeorg.openhab.core.library.types.QuantityTypejava.time.LocalDatejava.time.LocalTimejava.time.LocalDateTimejava.util.Datejava.time.ZonedDateTimejava.time.Instantjava.time.Duration
If an action method is annotated with @RuleAction and it returns a value, its return value needs to be annotated.
Depending on the return type, either @ActionOutput or @ActionOutputs needs to be used.
If you return a single value, add the @ActionOutput annotation.
If you return multiple values, you do so by returning a Map<String, Object> and adding the @ActionOutputs annotation.
Please note that it of course is still possible to return a Map<?, Object>, e.g. a Map<Instant, Object> for a collection of values with timestamps, but this return value cannot be used by rule actions (in UI-based rules) or the REST API.
As the return value needs to be serialised to be sent over the REST API, only a limited set of output types are supported by the REST API.
If an action method has a return value that has an unsupported type, the action's return value cannot be used by rule actions (in UI-based rules) or the REST API.
The return value can still be used in automation languages.
The supported output types are (see AnnotationActionHandler (opens new window)):
boolean,int,float,String, and their boxed counterparts org.openhab.core.library.types.QuantityTypejava.math.BigDecimaljava.time.LocalDatejava.time.LocalTimejava.time.LocalDateTimejava.time.ZonedDateTimejava.time.Instantjava.time.Duration
TODO
There must still be the ability to configure the binding via text files (.things and .items), also if you implement an automatic discovery of Things.
| Field | Description |
thingUID | The thingUID is the unique identifier of the specific discovered thing (e.g. a device's serial number). It must not be constructed out of properties, that can change (e.g. IP addresses). A typical thingUID could look like this: hue:bridge:001788141f1a |
thingTypeUID | Contrary to the thingUID is the thingTypeUID that specifies the type the discovered thing belongs to. It could be constructed from e.g. a product number. A typical thingTypeUID could be the following: hue:bridge. |
bridgeUID | If the discovered thing belongs to a bridge, the bridgeUID contains the UID of that bridge. |
properties | The properties of a DiscoveryResult contain the configuration for the newly created thing. |
label | The human readable representation of the discovery result. Do not put IP/MAC addresses or similar into the label but use the special representationProperty instead. |
representationProperty | The name of one of the properties or configuration parameters, which best discriminates the result from other results of the same type. See chapter Representation Property below. |
For UPnP, mDNS and SDDP there already are generic discovery services available.
Bindings only need to implement a UpnpDiscoveryParticipant, mDNSDiscoveryParticipant resp. SddpDiscoveryParticipant.
For details refer to the chapters UPnP Discovery, mDNS Discovery and SDDP Discovery.
if (thingUID != null) {
# Representation Property
.build();
.build();
public String uniqueId;
# Background Discovery
@Override
@Override
wemoDiscoveryJob = null;
# Active Scan
@Override
public void startScan() {
if (lights != null) {
for (FullLight l : lights) {
onLightAddedInternal(l);
// search for unpaired lights
# Ending an Active Scan
# Remove older results
@Override
super.stopScan();
Hint!
The developer has to take care about that.
# UPnP Discovery
Additionally one must add <feature>openhab-transport-upnp</feature> to the binding's feature.xml file.
getSupportedThingTypeUIDs- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID- Creates a thing UID out of the UPnP result or returnsnullif this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult- Creates theDiscoveryResultout of the UPnP result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUIDmethod to create the thing UID of the result.getRemovalGracePeriodSeconds(OPTIONAL) - Returns an additional grace period delay in seconds before the device will be removed from the Inbox. This method is called when the discovery service is about to remove a Thing from the Inbox. Some bindings handle devices that can sometimes be a bit late in sending their 'ssdp:alive' notifications even though they have not really gone offline. This means that the device is repeatedly removed from, and (re)added to, the Inbox. To prevent this, a binding may OPTIONALLY implement this method to specify an additional delay period (grace period) to wait before the device is removed from the Inbox.
@Override
return Set.of(THING_TYPE_BRIDGE);
@Override
if (uid != null) {
return result;
return null;
@Override
if (details != null) {
if (modelDetails != null) {
if (modelName != null) {
return null;
The following is an example of how to implement the OPTIONAL getRemovalGracePeriodSeconds method.
@Component(configurationPid = "discovery.hue")
private long removalGracePeriodSeconds = 15;
@Activate
public void activate(@Nullable Map<String, Object> configProperties) {
updateRemovalGracePeriod(configProperties);
@Modified
public void modified(@Nullable Map<String, Object> configProperties) {
private void updateRemovalGracePeriod(Map<String, Object> configProperties) {
if (configProperties != null) {
Object value = configProperties.get(HueBindingConstants.REMOVAL_GRACE_PERIOD);
if (value != null) {
try {
removalGracePeriodSeconds = Integer.parseInt(value.toString());
} catch (NumberFormatException e) {
logger.warn("Configuration property '{}' has invalid value: {}",
HueBindingConstants.REMOVAL_GRACE_PERIOD, value);
@Override
public long getRemovalGracePeriodSeconds(ServiceInfo serviceInfo) {
# mDNS Discovery
getServiceType- Defines the mDNS service type (opens new window).getSupportedThingTypeUIDs- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID- Creates a thing UID out of the mDNS service info or returnsnullif this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult- Creates theDiscoveryResultout of the mDNS result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUIDmethod to create the thing UID of the result.getRemovalGracePeriodSeconds(OPTIONAL) - Returns an additional grace period delay in seconds before the device will be removed from the Inbox. This method is called when the discovery service is about to remove a Thing from the Inbox. Some bindings handle devices that can sometimes be a bit late in sending their mDNS notifications even though they have not really gone offline. This means that the device is repeatedly removed from, and (re)added to, the Inbox. To prevent this, a binding may OPTIONALLY implement this method to specify an additional delay period (grace period) to wait before the device is removed from the Inbox. See the example code for thegetRemovalGracePeriodSeconds()method under the "UPnP Discovery" chapter above.
# SDDP Discovery
SDDP discovery is implemented in the framework as SddpDiscoveryService.
To facilitate the development, binding developers only need to implement a SddpDiscoveryParticipant.
Additionally one must add <feature>openhab-core-config-discovery-sddp</feature> to the binding's feature.xml file.
getSupportedThingTypeUIDs- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID- Creates a thing UID out of the SDDP service info or returnsnullif this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult- Creates theDiscoveryResultout of the SDDP result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUIDmethod to create the thing UID of the result.
It should extend the AbstractThingHandlerDiscoveryService (which implements ThingHandlerService and DiscoveryService) just like a normal service.
Since a new service is created for each thing, it has to be a PROTOTYPE component:
@Component(scope = ServiceScope.PROTOTYPE, service = YourBindingDiscoveryService.class)
public class <YourBindingDiscoveryService> extends AbstractThingHandlerDiscoveryService<YourBridgeHandler> {
In the class there is a field protected YourBridgeHandler thingHandler; which is automatically assigned.
This field is guaranteed to be non-null after the service has been activated.
During service creation, first activate() is called, then the thingHandler is injected and finally ìnitialize() is called.
The opposite order is used when the service is destroyed, first dispose() is called (when the thing handler is still available in the service), then deactivate().
initialize() and dispose() take care of background discovery.
If you need additional code for initializing / disposing the discovery service, you can place them in the initialize() / dispose() methods.
To ensure everything is working correctly, you should call super.initialize() AFTER your own code and super.dispose() BEFORE your own code.
The thingHandler can be used to get the bridge UID or to get access to the configured device connected to the bridge handler.
Fields set in activate() or initialize() can be regarded as "injected" and therefore be annotated with @NonNullByDefault({}).
private @NonNullByDefault({}) ThingUID bridgeUid;
@Override
bridgeUid = thingHandler.getThing().getUID();
super.initialize();
@Override
return List.of(YourBindingDiscoveryService.class);
Various add-on related questions are answered in our Add-on development FAQ.
